System Integrators and Motion Control Specialists
Text Box: CR
Text Box: Solutions
View Mitsubishi Robot Product Range
A range of High Speed SCARA and Articulated Robots with controllers From 1Kg Payload.
The New Generation of PC Based software packages for 3D modelling, programming and simulation of production cells with for industrial robot systems.
The graphics use Open GL standard. Graphic range from a simple wire-frame model to shaded visualisation with several light sources and removal of hidden surfaces.
Robot Programming  IRL (DIM 66312)
Movemaster Command and Melfa Basic  III, IV
Programming Assistant with syntax check
Automatic generation of trajectories
Real-time simulation
Sensor and process simulation
Simulation of chain link trunking
Collision detection
Multitasking
To enable us to offer a complete motion solution, we supply a range of ancillary equipment,
Mitsubishi Robots
Linear Actuators
Transformers
Gearboxes
Case study on Airbus UCCM project...(more)
home | products | services | about us | contact us
